Digiface AES
192 kHz Digital USB Interface with AES/SPDIF/ADAT/Analog I/O
Digiface AES
Products
Digiface AES
The latest Digiface AES is a professional, bus powered 14 input and 16 output channel USB 2.0 interface with 2 Mic/Line universal analog input channels and 4 analog output channels (2 XLR, one TRS phones) complementing its digital I/O section. With an excellent set of digital connectivity, SteadyClock FS, full stand-alone operation and built-in parametric EQ, the Digiface AES shines as the perfect all-in-one solution for recording and playback of digital and analog sources, as well as flexible playback/monitoring via TotalMix FX.
Connectivity and Features
2 x Mic/Line Input
2 x XLR Out
1 x Phones Output
1 x AES I/O via XLR
1 x SPDIF I/O Coax
1 x SPDIF I/O
1 x ADAT I/O
1 x MIDI I/O
Sample Rate Converter
SteadyClock FS
TotalMix FX
USB bus-powered
ARC USB
Class Compliant Mode
Buspower compatibility meets flexible Analog I/O Performance
For the main inputs RME uses the proven mic/line preamps in XLR combo configuration of the Babyface Pro FS. Two digitally controlled preamps provide individually switchable 48V phantom power. These circuits feature a gain range of 75 dB, adjustable in steps of 1 dB, including a relay-driven PAD, resulting in exceptional EIN (Equivalent Input Noise) performance as well as line overload protection, and enough gain for even the lowest level microphones.
On the back of the Digiface AES there are 2 balanced analog outputs via XLR male to drive power amps, active monitor speakers, or recordings. The headphone output allows additional and independent high quality monitoring, providing sufficient output power and volume on high and low impedance headphones.
2 Mic/Line universal analog input channels and 4 analog output channels (2 XLR, one phones)
Versatile Digital Input and Output Connectivity
The comprehensive set of digital I/Os, centered around an AES/EBU input and output via XLR, also includes SPDIF coax, SPDIF optical or 8-channel ADAT. All I/Os can be used simultaneously, turning the unit into a swiss army knife interface that receives and sends all common digital audio formats. An integrated SRC (Sample Rate Converter) can be switched to one of the three inputs to solve clocking issues and to adapt to other sample rates. This allows, for example, the device to be AES clock-synchronized from the main source and to listen to SPDIF independently at the same time. MIDI I/O via an included breakout cable completes the package.
ADAT, SPDIF, AES - A comprehensive set of digital I/Os
Full Stand-alone Functionality
Convenient, direct access and control of all features and the device is available directly from the front panel. Four keys and the encoder, the high-resolution and clear color display, and a well thought-out menu structure allow for quick changes and configuration of the device.
Six different device setups can be stored into internal memory. With these the interface transforms into totally different devices by the simple click of a button, which is especially useful in stand-alone mode. Furthermore TotalMix FX can also be controlled externally via MIDI.
Flexible mixing and monitoring with TotalMix FX & TotalMix Remote
Powerful Applications for Mixing, Monitoring and Measurement included
The Digiface AES also includes the powerful digital real-time mixer TotalMix FX. It allows fully independent routing and mixing of input and playback channels to all physical outputs. Independent stereo submixes plus a comprehensive Control Room section offer unrivalled monitoring capabilities and unsurpassed routing flexibility.
TotalMix Remote, enhances the power of RME interfaces by enabling remote control via iOS, PC or Mac. With a straightforward set up process — simply enter the IP address of the computer you would like to control with TotalMix Remote and get going — users can quickly adjust any aspect of TotalMix FX on a host system while walking around the studio with their tablet, or from a control room located elsewhere in the facility.
More Outstanding Features
SteadyClock FS - Reference class Digital Clocking
Excellent performance in all clock modes and High Quality Analog Conversion to hear your mix as it is, with lowest jitter and highest jitter immunity.
Find out more
TotalMix FX - Mixing/Routing with superior features for Studio and Live Work
Since 2001 TotalMix added unlimited routing and mixing to RME‘s audio interfaces. Its unique capability to create as many independent submixes as output channels available turned it into the most flexible and powerful mixer of its kind.
Find out More
DigiCheck - The Secret Weapon of High Resolution Audio Measurements
RME Audio interfaces not only provide you with a professional digital audio interface, but also with a free available software tool: DigiCheck, for metering, testing, measuring and analyzing digital audio streams.
Find out More
RME USB - Transport audio with lowest latency and industry leading stability
Use your RME audio interface on Mac and PC with reliable, stable, and regularly updated drivers for our products. RME Audio develops its own interface core, it’s not dependent on 3rd parties for upgrades, modifications or bug fixes, so customers can use latest operating systems without interruption or delay."
Find out More
Specs
Digiface AES
Analog
Microphone/Line In 1-2, XLR
  • Input: XLR, electronically balanced
  • Input impedance balanced @ 1 kHz: 2 kOhm, PAD 5,3 kOhm
  • Input impedance unbalanced @ 1 kHz: 1 kOhm, PAD 2,6 kOhm
  • Maximum input level, Gain 0 dB: +8 dBu, PAD +19 dBu
  • Maximum input level, Gain 75 dB: -67 dBu, PAD -56 dBu
  • Gain range: 75 dB
  • EIN: -129 dBu A-weighted, 60 dB gain,150 Ohm, 20 Hz – 20 kHz
  • Signal to Noise ratio (SNR): 113 dB RMS unweighted, 115 dBA
  • Frequency response @ 44.1 kHz, -0,1 dB: 16 Hz – 20,4 kHz
  • Frequency response @ 96 kHz, -0,5 dB: 7 Hz – 45,8 kHz
  • Frequency response @ 192 kHz, -1 dB: 5 Hz – 88 kHz
  • Frequency response PAD @ 44.1 kHz, -0,1 dB: 5 Hz – 20,4 kHz
  • Frequency response PAD @ 96 kHz, -0,5 dB: 2,5 Hz – 45,8 kHz
  • Frequency response PAD @ 192 kHz, -1 dB: 2 Hz – 88 kHz
  • THD: < -110 dB, < 0,0003 %
  • THD+N: < -106 dB, < 0,0005 %
  • Channel separation: > 110 dB
TRS In 1-2
As XLR, but:
  • Input: 6.3 mm TRS jack, electronically balanced
  • Input impedance @ 1 kHz: 12 kOhm balanced, 6 kOhm unbalanced
  • Maximum input level, Gain 0 dB: +24 dBu
  • Maximum input level, Gain 75 dB: -51 dBu
  • Frequency response @ 44.1 kHz, -0,1 dB: 2 Hz – 20,3 kHz
  • Frequency response @ 96 kHz, -0,5 dB: 1,5 Hz – 44,3 kHz
  • Frequency response @ 192 kHz, -1 dB: 1 Hz – 70 kHz
DA, Line Out 1-2
  • Output: XLR, electronically balanced
  • Output level switchable +19 dBu, +13 dBu, +4 dBu
  • Dynamic range (DR) @ +19 dBu: 120 dB (AES17), 123 dBA
  • Dynamic range (DR) @ +13 dBu: 114 dB (AES17), 116,5 dBA
  • Dynamic range (DR) @ +4 dBu: 114 dB (AES17), 116,5 dBA
  • Frequency response @ 44.1 kHz, -0,5 dB: 0 Hz – 20,7 kHz
  • Frequency response @ 96 kHz, -0,5 dB: 0 Hz – 45 kHz
  • Frequency response @ 192 kHz, -1 dB: 0 Hz – 90 kHz
  • THD+N: -110 dB, 0,0003 %
  • Output impedance: 300 Ohm
DA - Stereo Monitor Output Phones (7-8)
as DA, but:
  • Output: 6.3 mm TRS jack,unbalanced
  • Output level at 0 dBFS, High: +13 dBu
  • Output level at 0 dBFS, Low: +7 dBu
  • Signal to Noise ratio (SNR) @ High: 120 dB (AES17), 122 dBA
  • Signal to Noise ratio (SNR) @ Low: 114 dB (AES17), 116,5 dBA
  • Output impedance: 5 Ohm
  • Max power per channel, 32 Ohm load, 0,1% THD: 160 mW
  • THD+N @ 32 Ohm Last: -108 dB, 0,0004 %
MIDI
  • 1 x MIDI I/O via breakout cable with 2 x 5-pin DIN jacks
  • Galvanically isolated by optocoupled input
  • Hi-speed mode: Jitter and response time typically below 1 ms
  • Separate 128 byte FIFOs for input and output
Digital
  • Clocks: Internal, AES, SPDIF, ADAT
  • Jitter suppression of external clocks: > 50 dB (> 1 kHz)
  • Effective clock jitter influence on AD and DA conversion: near zero
  • Digital Bitclock PLL for trouble-free varispeed ADAT operation
  • Supported sample rates: 28 kHz up to 200 kHz
Digital Inputs
AES/EBU
  • 1 x XLR, transformer-balanced, galvanically isolated, according to AES3-1992
  • High-sensitivity input stage (< 0.3 Vpp)
  • SPDIF compatible (IEC 60958)
  • Accepts Consumer and Professional format
  • Lock range: 27 kHz – 200 kHz
  • Jitter suppression: > 50 dB (> 1 kHz)
SPDIF coaxial
  • 1 x RCA,according to IEC 60958
ADAT Optical
  • 2 x TOSLINK, Format according to Alesis specification
  • Standard: 8 channels 24 bit, up to 48 kHz
  • Double Speed (S/MUX): 4 channels 24 bit 96 kHz
  • Quad Speed (S/MUX4) : 2 channels 24 bit 192 kHz
  • Bitclock PLL ensures perfect synchronisation even in varispeed operation
  • Lock Range: 31.5 kHz – 50 kHz
SRC
  • The inputs AES, SPDIF coaxial or SPDIF optical switchable
  • 2 channels, 32 up to 192 kHz
  • Max. conversion ratio. 1:7 and 7:1
  • THD+N: -139 dB
  • Dynamic range (DR): 139 dB (AES17), 142 dBA
  • Latency: 109 Samples, 2,47 ms @ 44,1 kHz, 1,14 ms @ 96 kHz, 0,57 ms @ 192 kHz
Digital Outputs
AES/EBU
  • XLR, transformer-balanced, galvanically isolated, according to AES3-1992
  • Output impedance 5 Vss
  • Format Professional according to AES3-1992 Amendment 4
  • Single Wire Mode, Supported sample rates: 28 kHz up to 200 kHz
SPDIF coaxial
  • 1 x Cinch, according to IEC 60958
  • Output impedance 0,7 Vss
  • Format Consumer (SPDIF) according to IEC 60958
ADAT
  • 1 x TOSLINK
General
  • Power supply: USB bus power or external power supply
  • Typical power consumption: 3 Watt
  • Current at 12 V external power: 250 mA (3 Watt)
  • Dimensions (BxHxT): 215 x 44 x 130 mm (8.46" x 1.73" x 5.1")
  • Weight: 880 g (1.94 lbs)
  • Temperature range: +5° up to +50° Celsius (41° F up to 122°F)
  • Relative humidity: < 75%, non condensing
All specifications are subject to change without notice.
Back
Drivers
Digiface AES
Flash Update
Release date
Download
Mac OS Flash Update Tool for MADIface XT/USB/Pro, OctaMic XTC, ADI-2 Pro Series & DAC, Digiface USB/AES/Dante/Ravenna, UFX II/III
Update to version: (*latest changes)
MADIface XT: USB 3/2 191, PCIe 56, DSP 42
MADIface USB, Hw Rev 6: 25
MADIface USB, Hw Rev 7: 101
MADIface Pro: 73
OctaMic XTC: USB 47, DSP 26
ADI-2/4 Pro SE: FPGA 72, DSP 40
ADI-2/4 Pro SE: FPGA 209, DSP 40
ADI-2 Pro Series: FPGA 267, DSP 128
ADI-2 DAC: FPGA 81, DSP 62
Digiface USB, Hw Rev X: 18
Digiface USB, Hw Rev G: 35
Fireface UFX II, Hw Rev A: USB 26, DSP 26, CC 15*
Fireface UFX II, Hw Rev E: USB 115, DSP 26, CC 112*
Fireface UFX II, Hw Rev 7: USB 206, DSP 26, CC 208*
Fireface UFX III: USB 20 DSP 21 CC 44*
Digiface Dante: 57*
Digiface Ravenna: 55
Digiface AES: USB 47, MCU 17, CC 11
Release date
2024-05-03
Windows Flash Update Tool for MADIface XT/USB/Pro, OctaMic XTC, ADI-2 Pro Series & DAC, Digiface USB, UFX II/III, UFX+, Digiface Dante, Digiface AVB
Update to firmware: (* latest change)
MADIface XT: USB 191 PCIe 56 DSP 42
MADIface USB: 25 (6), 101 (7)
MADIface Pro: 73
OctaMic XTC: 47/26
ADI-2 Pro series: FPGA 267, DSP 128
ADI-2 DAC series: FPGA 81, DSP 62
UFX II: USB 26 DSP 26 CC 15 (A), USB 115 DSP 26 CC 112 (E), USB 206 DSP 26 CC 208 (7)*
UFX+: USB 55 DSP 58 Thunderbolt 112 (A), USB 72 DSP 58 Thunderbolt 167 (E)*
Digiface USB: 18 (X), 35 (G)
Digiface AVB: 260*
Digiface Dante: 57*
Digiface AES: USB 47 MCU 17 CC 11
Release date
2024-05-03
Mac OS X
Release date
Download
MADIface Pro: 73
Digiface Dante: 57*
Release date
2024-05-03
macOS 11 or up USB Series DriverKit Driver
macOS 11 or up (Big Sur, Monterey, Ventura and up) Check OS Version USB series DriverKit driver, v. 4.10.
Release date
2024-01-18
macOS 11 and up USB Series Kernel Extension Driver
USB 2/3 Kernel Extension driver for macOS 11 ( Big Sur, Monterey, Ventura and up) Check OS Version. Version 3.31. Supports Intel and Mx.
Release date
2024-01-17
macOS 10.12 up to 10.15 driver for Fireface UFX / UFX+ / UFX III, UFX II, 802, UCX, UCX II, UC, Babyface, Babyface Pro, MADIface XT/USB/Pro, Digiface USB/AES/Dante/Ravenna
version 3.223. Compatible to 10.12 (macOS Sierra) up to 10.15 (macOS Catalina) Check OS Version. Mx users please download macOS 11 and up USB Series Driver.
Release date
2024-01-16
Mac OS X driver for Fireface UFX / UFX+ / UFX II, 802, UCX, UCX II, UC, Babyface, Babyface/Pro, MADIface XT / USB / Pro, Digiface USB - Legacy Build
Version 2.23. Compatible to 10.9 (OS X Mavericks) up to 10.13 (macOS High Sierra) Check OS Version. Legacy build, newer drivers are version 3.x. M1 user please download macOS 11 and up USB Series Driver.
Release date
2021-10-05
Windows
Release date
Download
MADIface Pro: 73
OctaMic XTC: 47/26
Digiface AVB: 260*
Digiface Dante: 57*
Release date
2024-05-03
Windows 10
Release date
Download
Windows USB driver for MADIface XT / USB / Pro, Fireface UFX+ / UFX II / UFX III, OctaMic XTC, ADI-2 Pro/AE/FS/DAC, ADI-2/4 Pro, Digiface USB / AES / Dante / Ravenna
Version 0.9833, Windows 8 and up.
Release date
2024-01-23
Windows 11
Release date
Download
Release date
2024-01-23
Windows 7
Release date
Download
Windows 7 USB driver for MADIface XT / USB / Pro, Fireface UFX+ / UFX II / UFX III, OctaMic XTC, ADI-2 Pro/AE/FS/DAC, ADI-2/4 Pro, Digiface USB / AES / Dante / Ravenna
Version 0.9827, last driver version for Windows 7.
Release date
2023-09-13
Windows 8
Release date
Download
Release date
2024-01-23
Mac OS X
Release date
Download
TotalMix FX Mac latest version (single file download)
TotalMix FX V 1.93. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2024-02-10
Download
tmfx_mac_193.zip
TotalMix Remote Mac
TotalMix Remote V 1.40 - App to remote control TotalMix FX via ethernet and WiFi from other devices with Mac OS 10.12 or up. Universal Binary, supports Intel and Mx. Please note: can not be run on the same computer where the host TotalMix FX is used. This download is not TotalMix FX, which is part of the driver installation.
Release date
2024-01-17
Windows
Release date
Download
TotalMix FX Windows latest version (single file download)
Release date
2024-02-10
Download
tmfx_win_193.zip
TotalMix Remote Windows
TotalMix Remote V 1.40 - Program to remote control TotalMix FX via ethernet and WiFi from other devices with Windows OS (PC, Tablet). Please note: can not be run on the same computer where the host TotalMix FX is used. This download is not TotalMix FX, which is part of the driver installation.
Release date
2024-01-17
Mac OS X
Release date
Download
DigiCheck NG macOS
Universal binary, runs natively on Intel and M1 machines. DigiCheck NG V 0.90 requires macOS 10.13 (High Sierra) or up.
Release date
2023-06-27
DIGICheck 0.73 Mac
Release date
2017-09-14
Download
dc_073_mac.zip
Back
Manuals
Digiface AES
Product
Description
Download PDF
Digiface AES
Manual for Digiface AES, version 1.2a, 06/2023
Product Images
Back
